2000 Ford Focus ENGINE STALLS
124,000 MILES • 4 CYL • FWD • AUTOMATIC
LEONCLAUDIA
NO VACCUM LEAKS NEW PLUGS NEW WIRES NEW FULE FILTER
CAR STALLS WHEN COMING TO STOP ONLY WHEN WARMED UP RPMS ARE LOW AS IF NOT DONW SHIFTTING IS THERE ANY COMMONN PROBLEM THAT I CAN LOOK INTO
Sep 4, 2008 at 9:04 PM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.
Sep 5, 2008 at 1:07 AM
