2000 Ford Focus Bad smell
126,000 MILES • 4 CYL • FWD • AUTOMATIC
DMCLANE
When I turn on my a/c this really bad smell comes out. I have had it looked at but nowone can find the problem. Also when I accelerate I can sometime hear water, it sounds like it's in the dash on the passenger side, and I was told that there is no water spot on the ground after the a/c has been running. What is it and how do I fix it. summer's are really hot in Texas!!
Apr 7, 2008 at 11:43 AM
BLACKOP555
  • 10,386 POSTS
can you describe the smell a little better? moldy? antifreeze scent?
Apr 7, 2008 at 11:55 AM
DMCLANE
I guess,it smells like mold.
Apr 7, 2008 at 12:24 PM
BLACKOP555
  • 10,386 POSTS
try a new cabin air filter first and try spraying a solution of bleach through the air vents then turn the blower on, that might solve it if not your valve that bleeds off the water vapor is plugged and keeping the water in the ducts.
Apr 8, 2008 at 8:04 AM
DMCLANE
Can you tell me where the cabin air filter is located? Also, the bleach helped a lot. I filled up with freon and now I have the water drip under the car (as it should do.)
Apr 9, 2008 at 12:09 PM
BLACKOP555
  • 10,386 POSTS
sorry, i cant tell you off hand where it is located try searching around the forums here.
Apr 9, 2008 at 2:29 PM
DMCLANE
thanks for your help.
Apr 9, 2008 at 2:42 PM
BMRFIXIT
  • 19,053 POSTS
did you call !! check under hood if you have one it will be on the write side check the picture
https://images.2carpros.com/forum/automotive_pictures/99387_focuscabin_1.jpg
Apr 9, 2008 at 3:07 PM
BLACKOP555
  • 10,386 POSTS
your welcome, thank you for your politeness.
and thanks bmr for the image.
Apr 9, 2008 at 3:22 PM
