2000 Ford Focus acceleration
MUTLEY1111
Engine Performance problem
2000 Ford Focus Two Wheel Drive Manual 86'000 miles
Hi there, ive got a ford focus 1.8 x-reg, thats done 86'000 miles. . . last month i had a problem that i think it was miss fireing, as i was accelerating it would judder erratic at times and struggle to get up to speed then it would kick in again, but every time i came to pulling off it would do it again, when i took it to the garage, they said it could be the coil, but they changed the spark plugs and the lead and it was working perfect, now after 3 weeks its doing it again, can this still be the coil ?? the garage i took it too has now closed down, but as it was working perfect i thought that that was the problem as 1 of the spark plugs had corroded and broken down??? please help me
Mar 15, 2010 at 8:14 PM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 15, 2010 at 8:21 PM
