2000 Ford Focus ABS and parking brake lights stay on
115,500 MILES • 4 CYL • 2WD • AUTOMATIC
G007AMERICA
The ABS and parking brake warning lights came on after replacing the rear wheel drums and wheel bearings on my Ford Focus ZTS . ABS is not currently working but the brakes work fine. Is there a way to reset the warnings without having to take the car to a repair shop? I thought I might have installed wheel bearings for a vehicle without ABS but after more research I found all Focus trim models came equipped with ABS brakes.
Mar 9, 2008 at 6:56 AM
MERLIN2021
  • 17,250 POSTS
You need the bearing with a reluctor, or ring gear or they will not operate!
Mar 9, 2008 at 6:59 AM
