2000 Ford Focus
PWILLY07
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 61,000 MILES
The car will not start, the engine turn over the battery is good, I try jump starting it it still wont start, it has gas in it.
Tuesday, May 25th, 2010 AT 8:25 PM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, May 25th, 2010 AT 8:31 PM
