2000 Ford Focus
90,000 MILES • 4 CYL • FWD • AUTOMATIC
MASONALAN80
my 2000 ford focus lx runs rough at idle and while driving. I replaced the fuel filter,o2 sensor, spark plugs and spark plug wires it still runs like crap not sure what it is and i need to know fast please!
thankyou
Mar 12, 2010 at 11:15 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on and if so should start by checking for codes
Mar 12, 2010 at 12:53 PM
MASONALAN80
check engine light is on and i get a misfire cylinder 3 code what do you think it could be. i replaced the spark plugs, the spark plug wires, o2 sensor, and fuel filter
Mar 13, 2010 at 2:15 AM
BMRFIXIT
  • 19,053 POSTS
Check if coil firing the cylinder
Do a compression test
Check injector
Mar 13, 2010 at 6:03 AM
MASONALAN80
i checked out the coil pack and it had cracks all over it so i replaced it and now the car runs fine. thanks for all of your help
Mar 25, 2010 at 3:19 AM
