2000 Ford Focus
86,500 MILES • 4 CYL • FWD • AUTOMATIC
KMOSHKOVICH
hi my 2000 ford focus on idle shakes. i opened the hook and i see the engine shaking in there and the performance on the car is lacking. acceleration is slower then how it used to be
what should i check?
Oct 7, 2010 at 8:11 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 12, 2010 at 6:08 PM
