2000 Ford Focus
61,000 MILES • 4 CYL • FWD • AUTOMATIC
PWILLY07
The car will not start,the engine turn over the battery is good,i try jump starting it it still wont start,it has gas in it.
May 25, 2010 at 1:25 PM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 25, 2010 at 1:31 PM
