2000 Ford Focus
RONSKI1969
2000 Ford Focus
My 2000 Focus over heated and it will not start. It also had 2 quarts too much oil in it, the dipstick showed way over the limit. The engine is not frozen, it still turns over when at the main pulley, gets gas to the sparkplugs, has spark, fuses are all good but still won't start. What could this be???
Sep 21, 2008 at 8:04 AM
RENAUDTN
  • 636 POSTS
Is your oil looking weird?
You may an internal leak (blown head gasket, cracked head/block) and you have coolant in your oil which is why your level is higher than it should be.
Sep 22, 2008 at 5:25 AM
