2000 Ford Focus
90,000 MILES • 4 CYL • FWD • AUTOMATIC
WORRELL65
Battery light comes on very spuratic for only 5 to 10 seconds at a time.Has new belt,plugs,wires,and alternator was removed and tested at two differant parts stores and passed test. I noticed that my headlights will dim breifly and brigthen back to normal sometimes while driving. The battery was also tested and is good. The battery light can cone on 5 times within 2 miles and not come on again for 2 weeks. the care is driven on a daily basis. Please help
Sep 10, 2008 at 10:14 AM
BMRFIXIT
  • 19,053 POSTS
Check the wiring harness
check the terminal wire at the alternator
Very common issue we find on ford that the terminal on the wire side no good
i would check it out
good luck
Sep 10, 2008 at 10:45 AM
