2000 Ford Focus
LESLIE27
Engine Performance problem
2000 Ford Focus
i have a 2000 ford focus which recently ran out of gas on me..when we put gas in it it would not start back..we've got a fuel pump rebuild kit, air filter, fuel filter, like 3 different sensors, fuel injectors, and a coil pack..and still it wont run..it'll start and when you try to drive it once the engine temp comes up it dies..plus it doesnt idle right..what could be my problem
Sep 14, 2008 at 4:47 AM
BMRFIXIT
  • 19,053 POSTS
need to check and make sure you have the correct fuel pressure
did you check for code s
I would check for codes and check fuel pressure
Sep 17, 2008 at 8:45 AM
