Sitting at idle it'll studder every 30sec or so, stomp the gas and it hesitates then revs fine. Driving at 45-50 or so and barely touch the gas and it stumbles then takes off.
Tried injector cleaner, air filter, Same.
Tried plug wires, Same, tried plugs , cleared up completly for one drive, next day same thing, getting worse.
Took it to the ford place, said #4 missing, said bad wires, (just replaced them) changed them anyway, still the same.
One thing i've notice is that there is a arcing/ticking sound when the engine studders comming from the left side of the dash, tach?
Im thinking cracked #4 coil post arcing into the dash thru the tach wires. What do ya'll think?
Thanks
Thanks
Aug 1, 2006 at 5:12 AM
