1999 Ford Focus
110,000 MILES • 4 CYL • 2WD • MANUAL
ANNEMARIEOKELLY
hi, when I change gear my car struggles to regain power and chugs like it might stall which it hasn't yet but I think it would if I didn't rev. Also its really struggling to pick up speed like when on a carriageway can takes several minutes to get past 50mph then very slowly get above that.
Hope u have an idea what it could be and if expensive to put right.
Thanks for your time.
Mar 25, 2010 at 12:24 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 25, 2010 at 11:41 AM
