Step down box replacement
130,200 MILES • 1.4L • 4 CYL
BAASMARTIN
Ford Figo. If i replaced the step down box underneath the steering for the hazards and indicator. must the new box be programmed before hazard and indicator will work?
Feb 7, 2019 at 10:25 PM
  • 110,248 POSTS
If you are referring to the flasher unit, it should not require reprogramming.
I'm not sure what symptoms you are having, so I thought I would add this link. It discusses signal issues, how to check, and how to repair.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Let me know if it helps.
Feb 8, 2019 at 11:51 AM
