2006 Ford Fiesta should there be corrosion?
46,685 MILES • 4 CYL • FWD • MANUAL
LUCETHADDEUS
My 2006 ford fiesta has just been for its 2nd MOT. I have been given a advisory notice about ;
the rear axle beam corroded &
Front subframe & both suspension arms slightly corroded!
Is this normal for a '06 car??
Jul 20, 2010 at 12:25 AM
  • 31,937 POSTS
Hi there,
As this is a MOT you must be in the UK, so do they still run salt on the roads to combat ice?
mark (mhpautos)
Jul 20, 2010 at 1:00 AM
LUCETHADDEUS
yes i am in the uk, and they do grit the roads in the bad weather! do u think this is the cause of it!?
Jul 25, 2010 at 9:59 AM
  • 31,937 POSTS
Hi there,
If they are using a salt based compound, then this will be adding to the problem, if you live on the coast also a factor, if the body proof sealing was not adequate also a factor.
mark (mhpautos)
Jul 25, 2010 at 11:55 AM
