2005 Ford Fiesta missfiring
2005 FORD FIESTA
42,000 MILES • 4 CYL • 2WD • MANUAL
CRAIGMCGLEISH
hi i have a missfire on cylinders 1 and 4 only when the cars temp is cold but if i push the accelerator slightly whilst engine is still cold all 4 cylinders fire i have fitted new coil pack plugs and leads not sure what is wrong with the car to do this cany you help???
Mar 31, 2009 at 9:58 PM
DAVE H
  • 13,384 POSTS
check, clean or replace the CKP (crankshaft position sensor) ... and check the wiring is not damaged !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_411.png
Mar 31, 2009 at 10:16 PM
CRAIGMCGLEISH
thanks will give this a go is there anything else it could be ford are telling me that it sounds although i need a new pcm but i am not happy at that answer as engine is fine when warm and running ok thanks
Apr 1, 2009 at 9:22 AM
DAVE H
  • 13,384 POSTS
If you brought your vehicle into my garage with the symptoms your describing, the first thing I would be checking after the coils is the CKP ... It produce's these symptoms when dirty or worn ! have a look at this first and repost with the result's and we will take it from there !! hope this helps .. let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_419.png
Apr 1, 2009 at 9:57 AM
