2001 Ford Fiesta rear drum removal and bearing nut torque
2001 FORD FIESTA
63,000 MILES • 4 CYL • FWD • MANUAL
JULESNTINKER
how do i remove the rear brake drum when the shoes are sitting behind a ridge worn into the drum?
Also, after replacing the shoes what is the rear wheel bearing tightening torque.
Feb 11, 2010 at 11:08 AM
DAVE H
  • 13,384 POSTS
fully release handbrake adjustment .. tap all around drum with hammer .. use 2 big screwdrivers to pry off drum .. you local autoparts store will be able to supply a repair manual with torque specs and repair information
Feb 15, 2010 at 8:31 PM
