2001 Ford Fiesta oil in water
HYWEL
Engine Cooling problem
2001 Ford Fiesta 4 cyl Two Wheel Drive Manual
we had aproblem with oil in the expansion tank and were told it was the head gasket had that done and the problem seems worse it is an 1800 turbo diesel please can you help
Jul 10, 2009 at 9:41 PM
  • 31,937 POSTS
Hi there,
When you get oil in the water after a head problem you always find it so hard to clean all the oil from the system, diesels are worse for this, i would get a good quality coolant flush, have the radiator professionally cleaned, swab the hoses where possible, and flush the cooling system with a cleaner, ask your spare parts outlet what they stock for this job, start here.
mark (mhpautos)
Jul 10, 2009 at 10:12 PM
