hi if you look at the back of your engine you should see two pipes going through the black casing where the wiper blades are and you should see a silver round shaped device with the two pipes going through it this is a heater valve if you take that off and replace with a new one you should get warm air. I just done this about two weeks ago had the same problem. if you need anymore advice e mail me. let me know how you get on.
Dec 27, 2008 at 3:37 PM
