1996 Ford Fiesta heating
MARCOB1401
  • 1996 FORD FIESTA
  • 4 CYL
  • FWD
  • MANUAL
  • 65,000 MILES
I have no heating in my 1996 fiesta I have cha ged the thermostat and flushed the cooling system out and this has done nothing I have tried bleeding the radiator with exspansion tank lid on and off but still no joy could any one help?
Tuesday, November 18th, 2008 AT 8:38 AM
DAVE H
  • 13,384 POSTS
Put a hosepipe onto inlet pipe on your heater core. And disconnect vehicles pipe off outlet. Run water through to check you are getting circulation and clean through core. Refill water system and bleed again. Then test heaters. When bleeding system have heaters blowing on hot?. Are then any other symptoms other than heaters not working? Overheating/rought running etc.
Tuesday, November 18th, 2008 AT 9:02 AM
