1994 Ford Fiesta main beam headlight
FORKLIFTBRI
Electrical problem
1994 Ford Fiesta 4 cyl Two Wheel Drive Manual 110.00 miles
problem with headlights on full beam .when side lights and dip beam are switch on everthing fine soon as full beam is switched on the lights go back to side lights only but dip beam will come on when switched on also headlight will not flash when lever pressed any ideas thanks brian
Aug 12, 2009 at 3:56 AM
DAVE H
  • 13,383 POSTS
check the bulbs are good .. and check/replace the switch
Aug 30, 2009 at 2:56 PM
