1992 Ford Fiesta cylinder head
94,000 MILES • 4 CYL • 2WD • MANUAL
CRAIG RADCLIFFE
I have a 1992 mk3 fiesta 1.6 rs turbo which has just had the cylinder head skimmed and a full new gasket kit replaced. the problem is its still doing the same as before. its pressurising the water and not flowing properly therefor running really hot when i switch it off it bubbles away and is left with little or no water in the expansion tank i have bled it time and time again and it satill persists! pls help!!!!!!!
Jul 1, 2010 at 12:33 AM
JIM SHIRRON
  • 77 POSTS
Have you tested the cap?
Jul 1, 2010 at 12:57 AM
CRAIG RADCLIFFE
yes i replaced the cap with a new one from ford anyway i also had the head pressure tested and vacuum tested when it was away being machined.
Jul 1, 2010 at 2:09 AM
