1992 Ford Fiesta AIR LEAK
BIGRED4
Engine Mechanical problem
1992 Ford Fiesta 4 cyl Two Wheel Drive Manual
MY ENGINE IS TICKING OVER SLOW THEN FAST THEN ALMOST CUTS OUT. I CHANGE A PIPE FROM THE OILFILLER CAP BECAUSE IT HAD A HOLE IN
Nov 11, 2008 at 3:28 AM
DAVE H
  • 13,383 POSTS
check air filter, vacuum pipes. fuel filter, spark plugs, plug leads, distributor cap, rotor arm clean or replace all of the above
Nov 18, 2008 at 7:21 AM
