1991 Ford Fiesta windscreen wipers
1991 FORD FIESTA
110,000 MILES • 4 CYL • 2WD • MANUAL
KWIKFIT
Hi. The wiper on the driver side does not work. With each "sweep" of the wipers it goes to move a little bit and then stops. the left hand wiper is fine. Im skint at the moment just wondered if you might know what it may be, if it could be a simple problem and how much i may be looking at cost wise? Thanks for any advise you can give.
Dec 2, 2008 at 8:59 PM
DAVE H
  • 13,384 POSTS
check the nut securing the wiper blade down is tight .. check the splines under the nut ... check the linkages coming off the motor ...
Dec 2, 2008 at 9:35 PM
