1989 Ford Festiva Clutch Slipping
Hi there,
This may be a bit involved if you don't do much work on cars, but a brief run down i listed here, if you want to do the job your self you will need a few tools that the normal drivers tool kit wont have. So best you get a work shop manual first and have a good read.
Battery disconnected.
all electrical connections on the gear box & speedo unhooked
Remove starter,
Jack up and place on stands under body.
Wheels off,
remove drive shafts both sides.
remove exhaust engine pipe.
undo shift cables & clutch controls.
support g/box remove all but one bell housing bolts
remove gear box mounts and Any cross members if in way.
remove if fitted tin access plate lower bell housing
with g/box supported remove last bolt and with draw gear box.
Remove clutch & remove fly wheel for machining.
Replace thrust bearing.
Re fit in reverse make sure the fly wheel is torqued to spec, you will need a clutch aligning tool to fit the clutch.
If you have all the tools needed and someone to help you read the text in the manual and make sure that you understand exactly what you are doing. It's not a hard job, but you have to understand what is required so that you and your car come out the other side in one piece.
Mark (mhpautos)
Suggested Repair
Use a workshop manual and the proper tools. Disconnect the battery, unhook gearbox electrical and speedometer connections, remove the starter, support the vehicle, and remove the wheels, both drive shafts, exhaust pipe, shift cables, and clutch controls. Support the gearbox, remove the mounts, crossmembers if needed, and bellhousing bolts, then withdraw the gearbox. Replace the clutch and thrust bearing, and have the flywheel machined. Refit in reverse, torque the flywheel to specification, and use a clutch alignment tool.
Conversation Summary
The owner of a 1989 Ford Festiva 1.3L with a 4-speed manual and 145,000 miles reported clutch slipping, power loss, smoke around the transmission, and a burning clutch smell. The expert outlined a clutch job: consult a workshop manual, remove the gearbox after disconnecting related components and drive shafts, replace the clutch and thrust bearing, machine the flywheel, and reinstall with correct torque and a clutch alignment tool.
