1999 Ford Festiva stalling
1999 FORD FESTIVA
13,500 MILES • 4 CYL • FWD • AUTOMATIC
BREALS
Engine stalls when stationary. Runs perfectly in cruise.
Total cut out but occasionally catches and runs again.
Seems worse when stationary and foot brake on.
Have had distributor checked and plug wires, now ok
one was replaced. Only seems to do it after engine reaches running temp. (plug lead replaced did not cure the prob. Mechanic suggests ECU might be the prob.
Cant this be tested.
Thanks in advance
Mar 31, 2009 at 12:10 PM
JAMES W.
  • 2,394 POSTS
Check your idle air control (IAC) valve. It may just have to be cleaned.
Mar 31, 2009 at 3:33 PM
