1999 Ford Festiva small oil leak
RACHELLET
Engine Performance problem
1999 Ford Festiva 4 cyl Manual 180000 miles
hi ford festiva is leaking alittle oil only when the car has warmed up not to much could it be a seal. i have tried putting some stop leak stuff in it but didn't work.
Aug 18, 2008 at 4:37 PM
  • 31,937 POSTS
Hi there,
The stop leak is a waste of time and money, wash the engine down and check for fresh leaks after a drive, check front seal, oil pressure switch rocker cover, as these are the most common places to leak from the engine. Now it is engine oil leaking?
Mark (mhpautos)
Aug 18, 2008 at 6:31 PM
