1999 Ford Festiva Brake Lights
1999 FORD FESTIVA
110,000 MILES • 4 CYL • 2WD • MANUAL
MEERKAT
My 2 rear brake lights/reverse lights aren't working. The centre one, located on the hatch door, is still working.
Is this a fuse problem or a wiring issue? Can I fix it myself easily and how?
Feb 6, 2008 at 11:38 AM
BMRFIXIT
  • 19,053 POSTS
[quote:5c80a56782="Meerkat"]Electrical problem
1999 Ford Festiva 4 cyl Two Wheel Drive Manual 110000 miles
Is this a fuse problem or a wiring issue? Can I fix it myself easily and how?[/quote:5c80a56782]
check /replace bulbs and if all ok
check combo switch---- ( signal switch)
Feb 6, 2008 at 12:59 PM
MEERKAT
Thanks for your help.
What's the combo switch and where is it?
Feb 6, 2008 at 2:19 PM
BMRFIXIT
  • 19,053 POSTS
[quote:04354559a3="Meerkat"]Thanks for your help.
What's the combo switch and where is it?[/quote:04354559a3]
Its the directional signal switch on steering column
Feb 7, 2008 at 5:38 AM
STANTON.1996
I was wondering if you could tell me where I find the reverse light switch on a 1999 ford festiva as my rear light doesn't work when I touch the breaks and I have changed the bulbs in the lights.Thanks,
L
Dec 15, 2012 at 5:20 PM
