1999 Ford Festiva 1999 Ford Festiva over revs
1999 FORD FESTIVA
160,000 MILES • 4 CYL • FWD • MANUAL
NEILLINTERN
Hey there,
I have a Ford Festiva, 1999 model. 160K's
It's been driving fine for the last 6 months. Suddenly, when driving last week it now over rev's when slowing down.
When changing down into 3rd and 2nd it rev's at 2,000 rpm, then when idle it flicks between 1,500 and 2,000 and then when the car stops, its rev's from 2,000 - 2,500 rpms! When you start from cold or warm, it revs at 2,000 rpms. Nothing seems wrong under the hood and the gas cable isnb't too loose.
I was thinking either the gas cable or the TPS(?) sensor system?
Any help would be greatly appreciated.
Thanks...
Apr 11, 2010 at 12:07 PM
Clean out the idle air control valve and the EGR valve to include testing the throttle position sensor also clean the MAF sensor with an approved cleaner
Apr 11, 2010 at 9:37 PM
NEILLINTERN
Hey, thanks for the info.....much appreciated.
As I don't have a Haynes manual, is there anywhere to get diagram of where the sensors are?
Thanks again
Apr 12, 2010 at 9:16 AM
Sir-you need a repair manual there are procedures that needs to be followed to make sure its within specs at this moment I don't have the info-Sorry
Apr 12, 2010 at 10:09 AM
