1998 Ford Festia clutch or acceleration
MC_TINY69
  • 5 POSTS
Engine Performance problem
1998 Ford Festiva Engine Size unknown Two Wheel Drive Manual ? miles
this is my first car.. for the 1st week or so it was fine. but now when i accelerate i have 2 change gear lot earlier (changing into 3rd gear at about 23 miles an hour) what could be the problem???
Mar 15, 2008 at 8:49 AM
MASTERTECHTIM
  • 4,750 POSTS
i dont get it. why do you have to change gears so soon? be as elaborative as you can.
Mar 15, 2008 at 9:08 AM
MC_TINY69
  • 5 POSTS
sorry didnt explain it clearly. when i get t around 23 its reving alot at around 3500
Mar 15, 2008 at 9:10 AM
MASTERTECHTIM
  • 4,750 POSTS
still not clear but i think your saying when you start off driving in a standard shift car that the rpms go real high without the car accelerating as quickly as it should. correct. this means your clutch is slipping and needs to be replaced.
Mar 15, 2008 at 9:14 AM
MC_TINY69
  • 5 POSTS
yep spot on!!!
i thought that might be the case.. is it an easy thing 2 replace~???
Mar 15, 2008 at 9:16 AM
MASTERTECHTIM
  • 4,750 POSTS
for me, yes. if you have never done one before it is a very difficult job. you need to remove the transmission to access it.
Mar 15, 2008 at 9:20 AM
MC_TINY69
  • 5 POSTS
ok i might give that a miss then!!! is it smething that needs seeing asap??
Mar 15, 2008 at 9:21 AM
MASTERTECHTIM
  • 4,750 POSTS
well thats a judgement call. it wont last long. be careful not to over rev your engine trying to get it to move
Mar 15, 2008 at 9:23 AM
MC_TINY69
  • 5 POSTS
ok thank you very much been a big help!!
Mar 15, 2008 at 9:25 AM
