1997 Ford Festiva Tapping noise in engine.
EMANUEL VAN MUNSTER
Engine Mechanical problem
1997 Ford Festiva 4 cyl Front Wheel Drive Automatic
Hi, hope you can help me here.
My Festiva has an occasional tapping noise in the engine.
It sounds for all the world like a loose tappet adjustment, but that cannot be so as the tappets are hydraulic.
The other strange thing is that if I am cruising at say 40Km /Hr when the tapping is loudest, if I quickly flick the ignition off and on again, the noise is gone and may not come back for quite some time.
If I drive at over about 60Km/Hr I never hear the tapping.
Could it be something electric, like perhaps a faulty fuel pump or something?
Jul 13, 2010 at 4:36 PM
POZZAAAAH32
HI,
My festiva does the same thing. does yours do this also when you turn on air conditioner? And does the tapping noise sometimes only occur when you press the accelorator down? If so, it could have something to do with the air conditioner belt. Mine's been doing it since I bought it a couple years ago and havn't had any major issues with it so I wouldn't worry too much.
Apr 7, 2011 at 4:59 PM
