1993 Ford Festiva starting?
152,000 MILES • 4 CYL • FWD • AUTOMATIC
THEMAN123466
hi my 93 festiva will not get spark. the car turns over fine and i have replaced the coil and the cap and the power unit. but someone told me to check out the computer in the car because that could cause the problem but what do you think i should do?
Jun 15, 2009 at 3:41 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jun 15, 2009 at 9:32 PM
