1993 Ford Festiva loosen tensioner on timing belt
1993 FORD FESTIVA
KATHYBRYSTIDWELL
Engine Cooling problem
1993 Ford Festiva 4 cyl Front Wheel Drive Manual
how do you loosen the tensioner on the timing belt
May 10, 2008 at 6:30 AM
SCOTTXD45
  • 26 POSTS
It is slotted on a single bolt. Just loosen the bolt and slide it to the rear. It is spring loaded so it will go back againsts the belt when you release it.
Jun 12, 2008 at 4:42 PM
