1991 Ford Festiva 1991 Ford Festiva Stalling/No Longer Star
ATLDEN
Engine Performance problem
1991 Ford Festiva
I posted a message concerning stating my ford festiva used to stall during idle, but now just does not start anymore. I got an answer from bluelightnin6 to check the spark and fuel pressure.
well, the spark is reaching the spark plugs but I was unable to check the fuel pressure because I was unable to locate the valve to connect the fuel pressure qauge. The Haynes manual shows that there is a little valve on the fuel rail, but my 1991 model does not seem to have the valve on the fuel rail. I suppose that the Haynes manual is showing a later model that does have the valve on the fuel rail. Where would I find this valve on my model? More to the point, how do I check the fuel pressure for a 1991 Ford Festiva? My donation is skimpy because this is a follow up question to the first question.
Jan 4, 2009 at 9:23 AM
2CARPRO JACK
  • 11,533 POSTS
Some vehicles dont have the schrader valve to tap into to verify fuel pressure.Those vehicles you have to interrupt the fuel lin with an adapter. Try spraying a little carb cleaner or starting fluid into the intake and see if it runs, if it does then you know you are chasing a fuel problem
Jan 4, 2009 at 11:53 AM
