1989 Ford Festiva Timing
80,000 MILES • 4 CYL • FWD • AUTOMATIC
DAHOSSMAN
How do I set the timing gear mark on the camshaft in relation to the crankshaft when replacing the head back onto the block?
Mar 9, 2008 at 1:10 PM
MY68MONTERAY
  • 17 POSTS
i belive there is a mark on the crank, if not turn the motor by hand so that cylinder #1 is at the top dead center position (all the way up) and your timing mark on the cam should line up to the top of the crank teeth
Nov 22, 2008 at 2:06 PM
