How do I set the timing gear mark on the camshaft in relation to the crankshaft when replacing the head back onto the block?
Mar 9, 2008 at 8:10 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
MY68MONTERAY
MEMBER
i belive there is a mark on the crank, if not turn the motor by hand so that cylinder #1 is at the top dead center position (all the way up) and your timing mark on the cam should line up to the top of the crank teeth
