1989 Ford Festiva carburetor problem
1989 FORD FESTIVA
240,000 MILES • 4 CYL • FWD • MANUAL
DROFNASD
The car starts fine, but when you push on the accelerator, it sputters and dies. I had the carb rebuilt and it started doing this.
Please help. I love my little beast and drive it everywhere when it is running.
( I have 8 other venicles and this is my choice.)
Sep 24, 2008 at 1:25 PM
Check the accelerator pump if its squirting fuel pull the throttle back look down the throat as you pull-you see fuel squirting. If not then its not rebuld properly. Also check the fuel pressure.
Sep 24, 2008 at 1:51 PM
