1988 Ford Festiva timing belt
120,000 MILES • 4 CYL • FWD • MANUAL
HMARK49
My timing belt was just replaced and it makes a rubbery squeaking noise, like tennis shoes on a polished floor, not a squealing noise. The belt has teeth that go into grooves on the pulley, the tensioner is working well and everything seems aligned, any suggestions?
Feb 1, 2008 at 8:03 AM
SCOTTXD45
  • 26 POSTS
Are you sure that it is the timeing belt and not the drive belt? Remove the drive belt a run the engine and see if it still makes the noise.
Jun 12, 2008 at 5:54 PM
