I have just purchased a Falcon wagon and the parking brake needs adjusting. It is a set of shoes inside the disk brake. how do they adjust.
Aug 5, 2009 at 5:30 PM
✓Experienced Mechanic
Hi there,
take off the wheel and there is a access hole to reach the adjuster, now these are often seized up, so you may have to remove the rotor and sort this out.try the adjuster first.
mark (mhpautos)
Aug 5, 2009 at 5:34 PM
BOOCHA J
MEMBER
[quote:82af2c5091="boocha j"]Brakes problem
2004 Ford Falcon 6 cyl Two Wheel Drive Automatic 95000 miles
I have just purchased a Falcon wagon and the parking brake needs adjusting. It is a set of shoes inside the disk brake. how do they adjust.[/quote:82af2c5091]
Thanks MHP it worked a treat just hard little things to find.
Aug 9, 2009 at 1:28 PM
