Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Falcon
Engine
Symptoms
Misfire
2002 Ford Falcon misfiring and stalling
2002 FORD FALCON
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADRIAN4
MEMBER
1 POST
hi, my xr6 has started to misfire slightly when i take off and is losing power in first gear. When i come to a stop it has also stalled at times.
Jul 11, 2010 at 9:30 PM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 11, 2010 at 10:24 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
