2000 Ford Falcon Keyless entry does not work
DK1975
Electrical problem
2000 Ford Falcon 6 cyl Two Wheel Drive Automatic 100K miles
I have recently bought a Ford Falcon 2000 and the keyless does not work. The keyless seems to work after a new battery was fitted. However, the car does not response to the keyless when I press something on it.
Radio/CD player do not work either, it say "Err" on the screen when I turned radio on.
Any idea what I should do?
Many thanks
Feb 18, 2010 at 11:38 AM
  • 31,937 POSTS
Hi there,
These Falcons have an ongoing problem with the central locking system, often this problem can be the master control unit, or the body control module, it will be a job for an auto elect to track down as it often is a rather tricky job to get it right, as for the radio, do you have the security code? if not your dealer will be able to get this off the master data base with your cars VIN No.
Mark (mhpautos)
Feb 19, 2010 at 8:12 AM
DK1975
Can someone get me a pdf file of the "FORD AUDIO SYSTEMS OPERATING INSTRUCTIONS" as I gues that there should be something done on the security system as the radio's screen display "Err" when I tried to turn it on.
I can not find the instruction anywhere on the web
Feb 20, 2010 at 12:00 AM
2 LINSEY
  • 287 POSTS
We appriciate your donation and look forward to helping in the future. Dont forget to get in touch with your local ford dealer for the info on your radio.
Thanks,
Linsey
Mar 1, 2010 at 6:44 AM
