HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Falcon
Engine
Intake Manifold
2000 Ford Falcon
KRJOSHI
MEMBER
2000 FORD FALCON
6 CYL
2WD
AUTOMATIC
210,000 MILES
How to clean the carbon from air intake manifold?
Friday, August 27th, 2010 AT 7:05 AM
MECHANIC
With the engine off, remove the intake pipe, open the throttle and clean with a good quality throttle body cleaner, spray and wipe away carbon from butterfly & throttle body.
Mark (mhpautos)
Thursday, September 2nd, 2010 AT 5:20 AM
Please
login
or
register
to post a reply.
Related Intake Manifold Content
2003 Ford Falcon Oil Sump
Hi Guys, My Car Is Blowing A Little Oil Out Of The Sump Through The Top Of The Dip Stick Shaft. This Seems To Indicate That Pressure &...
Asked by
vizart
2003
FORD FALCON
VIDEO
How to Build a Ford 302 Small Block - Part 8:
Instructional repair video
1992 Ford Falcon Oil Filter
Engine Mechanical Problem 1992 Ford Falcon 4 Cyl Two Wheel Drive Automatic I Have Drained The Oil But I Cant Seem To Be Able To Get...
Asked by
Kassie168
1 ANSWER
1992
FORD FALCON
2005 Ford Falcon Engine Conversions
I Have A Ford Falcon Utillity, Ba Mk11 Xl 4.0l 6cyl And Was Woundering If They Could Take A V8 Engine? If So Would There Be Any Other...
Asked by
joelruss
1 ANSWER
2005
FORD FALCON
2004 Ford Falcon Ecu Codes
Electrical Problem 2004 Ford Falcon 6 Cyl Two Wheel Drive Manual Is There A Way I Can Look At The Fault Codes From The Ecu Without...
Asked by
nuts460
1 ANSWER
3 IMAGES
2004
FORD FALCON
2003 Ford Falcon Ecu Problems
My Ecu Started Playing Up The Abs Light Would Come On Then My Engine Would Stall I Found Out That My Battery Wasn't Putting Out Enough Cold...
Asked by
shanelincoln
1 ANSWER
2003
FORD FALCON
VIEW MORE
Coolant Leak Symptoms
Throttle Body Actuator Service Toyota Prius 2
Throttle Body Service
