1999 Ford Falcon
1999 FORD FALCON
YASH
1999 Ford Falcon 6 cyl
999 Ford Falcon 6 cyl Automatic HI I M YASH I HAVE 1999 FORD FALCON ON LPG AND I M GETTING PROBLEM IS THAT WHEN I START MY CAR IT USED TO MISFIRING AND WHEN I PUT IT ON DRIVE IT JUST MISFIRES AND STOPS SO CAN YOU PLZ TELL ME THAT WHAT IS THE PROBLEM IN IT AND WHATS ITS SOLUTION. THANKS REGARDS YASH
Oct 10, 2010 at 9:58 PM
  • 31,937 POSTS
Hi there, check for faulty ignition leads, if they have a white or grey coating change them, this is cross firing, also check for any vacuum hoses off check the 3 at the rear of the manifold, check the MAP sensor, check that the inlet manifold gasket is not leaking, all common problems with Falcons.
Mark (mhpautos)
Oct 21, 2010 at 4:05 PM
