1998 Ford Falcon fuel regulator
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
MCQUILLAN62
hi ive replaCED FUEL pump starter motor battery and still having problems..we were told it was the fuel regulator so replaced car started drove home turned off.come out to kick car over back to square one wont start again..any solutions
Jan 29, 2010 at 4:38 PM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 29, 2010 at 7:54 PM
