1997 Ford Falcon
JO1974
1997 Ford Falcon
brake lights dont work but have checked the fuses and globes and they are all working
Dec 9, 2008 at 10:00 PM
MIKE H R
  • 3,094 POSTS
Check power going to brake light switch with a static tester. if it has power to it then check power comming out when pedel is pushed down, if you find power going in and none comming out when pedel is pushed the problem could be in the switch itself.
Dec 16, 2008 at 2:08 PM
