1996 Ford Falcon Rear brake Calipsers
1996 FORD FALCON
314,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKYESPARKLE
Hi, i need to fix my handbrake as the rear brake calipsers have siezed. I was sondering what i would need to fix this?
I also need to get a new horn and was wondering do horns need to be specifically for a certain car or do they generally just fit it any vehicles?
Thanks, Skye
Aug 3, 2009 at 4:31 PM
  • 31,937 POSTS
Hi there, the calipers can be o/hauled the kits are not that expensive, this is best left to a mechanic to do, as for the horn, any 12 horn will work.
Mark (mhpautos)
Aug 3, 2009 at 4:37 PM
SKYESPARKLE
thanks for that and also i have an oil leak as the powersteering fluid is leaking, would that mean i need a new power steering pump???
also would a headlight for an Xf fit my XH ute??
Aug 3, 2009 at 4:52 PM
  • 31,937 POSTS
Hi there,
If the pump is leaking, you can get a change over unit, as for the head light if its a round sealed beam or globe type it will.
mark (mhpautos)
Aug 3, 2009 at 5:05 PM
