1996 Ford Falcon accleration problem
PARMINDERSINGH
1996 Ford Falcon 6 cyl Two Wheel Drive Automatic
hi,
i have a ford falcon gli, 1996. when i press the accilrator and then release the accilrator but the speed remains same, it means that after releasing the accilrator pad the rpm does not go down it still stuck to 1500 rpm. then i shift my car neutal and then again i shift it into drive after that my car engine comes to ideal rpm.
Dec 2, 2009 at 11:35 AM
  • 31,937 POSTS
Hi there,
Have the throttle body checked, check for vacuum leaks, have the idle control motor check as well.
mark (mhpautos)
Dec 2, 2009 at 12:58 PM
