1995 Ford Falcon
MRPERUANO
Electrical problem
1995 Ford Falcon 6 cyl Two Wheel Drive Automatic
just bought new alternator got old one out, i cannot find the tensdion pulley so set it all properly as i had to use force to get it off.
Oct 8, 2010 at 3:26 PM
  • 31,937 POSTS
There is a 3/8" drive fitting at the lower portion of the 2 pulley assembly this is where you fit a breaker bar, pull the fans out for better access, this is just 2 10mm bolts at each top corner and 2 electrical plugs under the top hose.
mark (mhpautos)
Oct 21, 2010 at 4:10 PM
