1992 Ford Falcon car stalls
JARRYDDELANY
  • 1992 FORD FALCON
1992 Ford Falcon 6 cyl Automatic
when I start my car, the revs go up then go down really quick and almost stalls, so I give it a little rev, then thelly just drop straight down again and sometimes stall on me at idoling
Saturday, February 27th, 2010 AT 8:55 PM
  • 31,937 POSTS
Hi there,
Is this an Australian EA-EB multi point engine?
Mark (mhpautos)
Saturday, February 27th, 2010 AT 9:44 PM
JARRYDDELANY
Yes it is.
Saturday, February 27th, 2010 AT 10:48 PM
  • 31,937 POSTS
Hi there,
OK common problems are MAP sensor on the fire wall, and the vacuum hose to the manifold, manifold gasket leak, idle control motor at the throttle plate, best you start with a fault scan, the MAP sensor should come up if it is the problem.
Mark (mhpautos)
Sunday, February 28th, 2010 AT 12:01 AM
JARRYDDELANY
How would I do a fault scan
Sunday, February 28th, 2010 AT 7:32 PM
  • 31,937 POSTS
You will need to take it to a work shop to get the scanner hooked up, it only takes a few min, it should not cost very much.
Mark (mhpautos)
Sunday, February 28th, 2010 AT 8:38 PM
JARRYDDELANY
Ok awesume thanks
Sunday, February 28th, 2010 AT 8:45 PM
