HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Falcon
Engine
Symptoms
Stall While Driving
1990 Ford Falcon FUEL
ROBBO57.COM
MEMBER
1990 FORD FALCON
6 CYL
2WD
AUTOMATIC
257,000 MILES
CAR STALLS ON ACCELERATION
Monday, November 2nd, 2009 AT 11:55 PM
MECHANIC
Hi there,
usual things on these are faulty coils and leads, vacuum leaks at the inlet manifold, they do come loose. Check injectors & fuel pressure change filter, and do a scan to check for any unresolved fault codes, start here.
Mark (mhpautos)
Tuesday, November 3rd, 2009 AT 4:42 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1990 Ford Falcon Stalls When Push Pedel Too Fast
Engine Performance Problem 1990 Ford Falcon 6 Cyl Two Wheel Drive Automatic Hello, I Live In Remote Area, 230 Ks Too Nearest Mechanic...
Asked by
xxxxbitter
1990
FORD FALCON
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
Engine Stalls
My 1960 Ford Falcon 144 C.I. Straight Six Engine Starts But Immediately Stalls. I Have Changed The Ignition Switch, Starter Relay...
Asked by
garyr1909
8 IMAGES
1961
FORD FALCON
1962 Ford Falcon Engine Stalls
The Engine Starts But Stalls Within 2 Seconds. I Have Replaced The Ignition Switch, The Spark Plugs, Distributor Cap And Rotor, The Coil...
Asked by
greeves
1962
FORD FALCON
2003 Ford Falcon Ba Falcon-engine Stalling While...
I Have An 03 Xr8 With 72000 On The Clock. All Stock Standard. Couple Of Weeks Ago I Was Driving Out Of Geelong And The Engine Went Dead....
Asked by
grays001
1 ANSWER
2003
FORD FALCON
1994 Ford Falcon The Engine Stalled Three Time Today...
Engine Mechanical Problem 1994 Ford Falcon 6 Cyl Two Wheel Drive Automatic Hi There, I Have A Ford Falcon Ed 94 Sedan, As I Was On...
Asked by
Siaki
1 ANSWER
1994
FORD FALCON
VIEW MORE
What to Do When a Check Engine Light?
How to Read Codes
How to Read Codes
